Re: Help needed to start 284
Posted by Oldihlover on May 08, 2014 at 17:30:54 from (209.143.50.156):
In Reply to: Re: Help needed to start 284 posted by El Toro on May 08, 2014 at 11:48:53:
I checked wiring and firing order. I also checked valve timing I thought cam had slipped time. All checked good. The compression seems alittle low at 75 psi. I added alittle oil to the cylinders and compression stayed the same. What has me really baffled is I put some fuel in each cylinder and still nothing. The thing I am not sure of is the vacuum advance system.
