Re: 400 rear axle hub bolts
Posted by kub6040 on May 09, 2014 at 20:46:01 from (99.195.172.81):
In Reply to: 400 rear axle hub bolts posted by Fudd on May 09, 2014 at 19:32:41:
Try turning the wheel so the bolt heads are down and soak a rag in acetone and lay where the wedge was it may soak in around the bolts and loosen them,May not help the paint but if you heat it,that will burn the paint , I have used kroil on somethings stuck like that and it didn't help . I do want to know what does work for you. I am a southerners and have bad ideas at times. Thanks Jimmy
