Re: seat spring
Posted by NNP on May 10, 2014 at 05:51:30 from (66.66.112.196):
In Reply to: seat spring posted by pete L on May 08, 2014 at 17:00:56:
I've had good luck with the weaving together of two old springs.
Or adding a coil spring to seats with shocks.
Buying one of those cheapo load leveling kits for car rear shocks will get you enough parts for a couple tractors.
Just cut the kit spring down to whatever you need.
