Re: Supera ignition problems
Posted by Charlie Seale on May 10, 2014 at 06:44:23 from (66.175.160.75):
In Reply to: Re: Supera ignition problems posted by wayne in mn on May 10, 2014 at 06:00:19:
I tried a new cap and got the same results. I get a weak spark sometimes when I break the points with a screwdriver with the switch on. could it be the condenser?
