if the rotor button is in place, clean the rotor button tip, inside contacts of ignition coil cap, top side of rotor button spring and bend the rotor button spring upwards, so that you are sure that it is contacting inside coil terminal. check ignition coil wire for continuity.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
