Re: Cub Low-Boy won't go
Posted by Brian60950 on May 10, 2014 at 18:20:37 from (75.241.189.195):
In Reply to: Cub Low-Boy won't go posted by steve alderman on May 10, 2014 at 18:05:58:
The input shaft to the trans is turning, aft of the clutch. It's a dry clutch located between the engine & trans, under that yellow tunnel flange.
I'm almost wondering if the axles have keyed shafts & a key could be sheared but I can't see any of the axle. The hubs appear to be butted up right against the axle housing with none of the axle visible from underneath. I can't tell if it's a keyed shaft or if it's a splined shaft. I'd imagine that if it was a splined shaft that suddenly stripped out, there would be some grinding and jerky attempts at motion or something. But it's like it's in neutral in all gears.
When I let off the clutch in gear, I can hear the engine RPMs drop just a tiny bit more than when I let off the clutch in neutral. So I know that gears inside the trans are at least turning.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
