Re: 1086 T/A
Posted by Larry B. 1486 on May 10, 2014 at 19:21:18 from (72.106.59.98):
In Reply to: 1086 T/A posted by Russell Moore on May 10, 2014 at 13:49:30:
It's very hard on the TA running it low on pressure to it. Like the rest said, add 5 gallon over the full mark. I run at least 30 gal in my 1486. Also check the hyd filter. Sounds a lot like the MCV pump getting weak. The MCV pump runs the steering, brakes and TA. A weak pump is one of the reasons of your TA going out. Not enough pressure to hold the clutches together from slipping.
