Hi Matt, first check the fuel shut off rod is working properly and is connected to the lever on top of the fuel injection pump. Next check the fuel flow out of the fuel tank. One of the fuel filters may have a glass bowl on the bottom with a drain screw, this is to drain off any water that may have collected in the fuel. There is a hand pump on right side of engine just above oil filter, this can be used to prime and bleed the fuel system. There are two bleed screws on the injection pump, bleed the lower one first then the upper one. Open bleed screw and pump the hand pump until fuel comes out the bleed screw without air bubbles, close bleed screw and repeat for next bleed screw.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father.
... [Read Article]
Latest Ad:
[More Ads]
