Re: 1973 international 3444 diesel backhoe just stopped
Posted by jimb2 on May 11, 2014 at 16:02:11 from (99.240.243.222):
In Reply to: Re: 1973 international 3444 diesel backhoe just stopped posted by 3444backhoe on May 11, 2014 at 15:50:07:
Is there a bleed screw on top of the filter
assembly? If so open it and pump until the fuel
flows out without bubbles, close and move onto
bleeders on injection pump, lower one first.
I am a little concerned that you are seeing air
bubbles in the glass bowl in bottom of filter.
Is there plenty of fuel in the tank? No visible
fuel line leeks between tank and hand pump?
Pull out crankcase dip stick and smell for Diesel
fuel and make sure crankcase oil lever is not over
full. Sometimes the diaphragm in the hand pump
develops a hole and pumps Diesel into crankcase
and air into fuel system.
