Re: Super C snow plow/grader
Posted by Rookie1 on May 11, 2014 at 20:12:02 from (69.78.223.102):
In Reply to: Super C snow plow/grader posted by Dan Nees on May 08, 2014 at 18:33:02:
I used the manual and made the parts to connect the blade as a grader blade. It bolts to the rear housing. just takes a little time and a measuring tape. cut the parts and weld them. Stabilizer bars take heat to bend them correctly. I had to made the shield shape arms for the lift. I went to a steel company and had them cut to length and then heated an bent mine to shape. I like the plasma cutter idea better. You just need someone to send you a cardboard cut out of one.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
