Re: Bought a Farmall A with a mystery part
Posted by Jim Becker on May 12, 2014 at 12:44:29 from (173.71.58.166):
In Reply to: Bought a Farmall A with a mystery part posted by Zachary Hoyt on May 11, 2014 at 12:03:58:
The inner end of the axle has 2 flats and a threaded hole in the end. There is a sort of special washer that fits over the end of the axle and is held with a cap screw. The outer edge of the washer is round with 4 sort of prong shapes sticking out around the edge. The shaft in the drive assembly has an end that vaguely resembles the shape of a socket. It has 4 notches that engage the 4 prongs. Maybe a spanner wrench would be a better comparison than a socket.
