I am presently working on a similar transmission from an early 47/ late late 46 Farmall BN. Facetiously speaking that hole is there so that you can accidentally knock you wrench down into while you are working on the tranny. In point of fact the same transmission was used on the A and B series tractors THAT whole is there so one may see into the differential section while the top / shifter cover is off and see if any work is needed on the differential section. These and a well built piece of machinery. If you are thinking about disassembly and replacing bearings and seals do it step by step and keep notes ( Even mental) but best on paper OR acquire a repair manuel By as many parts from your local bearing supply over IHC >> Check costs with both. Both will have comparable bearings and seals; probably made in the same plant. Best of the day to you, write me if you desire to. Wm.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
