Re: 300 utility hydraulics dumb question
Posted by DeltaRed on May 13, 2014 at 07:22:46 from (65.100.146.82):
In Reply to: 300 utility hydraulics dumb question posted by glacier-tractor on May 13, 2014 at 05:43:14:
Did you look at them before you removed them?The suction hose should be different than the pressure.So unless each hose is exactly the same,it should be pretty self explanetary.The fittings should be different so they should only go together one way.Next time,draw a picture,I do that frequently.Helps with reassembly!
