Re: Needing info on International Industrial M
Posted by Matt E. on May 13, 2014 at 12:05:42 from (173.216.243.183):
In Reply to: Needing info on International Industrial M posted by highcropwife on May 12, 2014 at 21:18:00:
[quote="dej(Jed)"](quoted from post at 11:40:45 05/13/14)
highcropwife said: (quoted from post at 21:18:00 05/12/14) I have an International Industrial M (Yellow) and would like information regarding it. It has been partially restored.
That would be a W-6 or I-6, not an M. I can't tell which though. If it had a pintle hitch, would likely be an I-6 but there appears to be an additional hitch or mount of some sort on the tractor. X1 is the code for gasoline engine. Should be a 1947 model based on the serial number you gave.
The I-6, W-6 and M were based on the same engine. The M looked completely different from the other two, it was a row crop tractor. Looks taller with adjustable rear wheels and usually a narrow front or an adjustable wide front. The I and W versions had the non-adjustable wide front like yours has and where the operator sits was lower on the tractor. Yours has an aftermarket cab on it.
Look at the serial number plate on the left side of the clutch housing where the serial number came from. It should also be stamped I-6 or W-6 I believe. The I-6 or industrial version was usually painted yellow but could be any color also. It appears to have a nice recent coat of paint. Could be a W-6 also, just painted yellow. Nice unit at any rate.
Good for you for getting ready to sell some of your husbands treasures. Sorry for your loss. I hope it goes to someone who will take care of it like your husband did and the tractor lives on to give another person joy of operating it.
This post was edited by Matt E. at 12:15:11 05/13/14.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
