Re: 450 hand throttle
Posted by Janicholson on May 13, 2014 at 14:46:48 from (74.60.94.18):
In Reply to: 450 hand throttle posted by Steve in Indiana on May 13, 2014 at 13:10:57:
Nope, the cotter pin, a washer, the spring, then the lever then the pivot hole, from away from you to toward you. The spring is to push the handle into the notches. Revolve the washer that fits the notches to get a square edge to it. Also you can use a small triangular file to re "square" the notches. Jim
