Re: Farmall M Turns Over Fast
Posted by rankrank1 on May 13, 2014 at 20:37:23 from (166.137.101.171):
In Reply to: Farmall M Turns Over Fast posted by farmallhal on May 13, 2014 at 06:09:57:
Marvel Mystery Oil does have recommendations on their cans I do believe, but I rarely use the Marvel as it is kinda pricey.
Typically, I use Cheap 2 stroke oil, ATF, or even 303 hydraulic oil if it is all I have at the time. I have no science to back it up, but older 2 stroke engines traditionally used 32 oz of cheap 2 stroke oil to 5 gallon of gas. This would be too rich and cause excessive smoking and carbon build up in a 4 cycle engine at that high of mixture. So I typically use about 10 oz of whatever oil per 5 gallon of gas.
Now if I add kerosene or diesel to the gas then I will up that to 1/2 gallon diesel to 5 gallon of gas. Or 3/4 gallon Kersene to 5 gallon of gas.
