Re: Always trust the pros
Posted by Tom Fleming on May 15, 2014 at 03:06:52 from (67.20.239.72):
In Reply to: Always trust the pros posted by Danby on May 14, 2014 at 21:47:45:
A good basic rebuild for a genny or starter that does not have bad field coils or windings is:
1.) turn commutator, undercut the mica
2.) replace brushes
3.) replace bushings
4.) replace felt in oil caps
Of course, a genny doesn't have a drive unit or switch, but those should be inspected and replaced if questionable.
Remember, that is a basic rebuild. Field coil replacement and armature rewinding require more effort and cost.
