You said "a few years." I think you're well beyond the statute of limitations on "do the right thing" here.
Just because you didn't use the lines does not mean that they didn't continue to deteriorate over the past few years. The pits are thin spots in the line where the steel is rusting away. Even if you do manage to stop the rust there will be areas that are borderline where a few years of vibration and a little bit of use will cause new leaks.
Regardless of your intentions for this tractor, I would recommend replacing with hoses and being done with it. You will only be chasing your tail on these pits until the pipe finally ruptures catastrophically.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
