Re: Mowing tires for H?,,
Posted by DaninKansas on May 15, 2014 at 15:03:06 from (24.248.193.103):
In Reply to: Mowing tires for H?,, posted by AlanA on May 15, 2014 at 09:30:40:
If all you are going to do is mow with them you can have some pretty nasty tires (especially on a lower HP tractor like an H) and get along just fine. I just wouldn't pull a loaded hay wagon in roadgear.
Neighbor had some fluid filled tires on the back of an old Massey Harris that were cracked to the tubes with large chunks of rubber peeled off the sidewalls. They were fine until the rusted out rims finally started to seperate. He still uses it some.
