400 3 pt.
Posted by 56 Fan 400 on May 15, 2014 at 15:15:00 from (75.196.254.17):
Attached are 2 pics of my drivers side (he he ) of the 3 pt. It was very very loose for reasons that should be apparent. I am trying to make it a bit more snug. It has the quick connect in the center under engine. I see on the 3pt pic that you can see a hole for a pin after you put the wobble point in. The wobble or pivot point fits over the shaft but also covers the stopper pin. My question is do I cut a slot in the pivot to fit a pin on the 3pt or is there a different way to do this??? If you notice, there was some grinding on the end of the shaft where someone had welded a nut as a stopper. Should I tap or die that tip and put a nut on it...??? If someone has a pic of theirs, it may help too. Thank you.
