Posted by jimb2 on May 15, 2014 at 17:17:00 from (99.240.243.222):
In Reply to: ih 584 lift problem posted by billey boy on May 13, 2014 at 17:03:39:
The hydraulic filter is in the round canister under the left foot rest. The filter can be changed without draining the trans/diff. Just put a bucket under and catch the hydraulic oil that is in the canister. Take note of how the old filter is installed. How often it should be changed is dependent on climate, operating conditions and does the parking brake work? is there a front end loader? One of the common problems on 74/84/95 series tractors is operator forgets to release the parking brake and drives the tractor chewing up the parking brake band into the hydraulic oil. It will clog the hydraulic filter and also cause the flower divider valve in the MCV valve to stick causing either PS and PB or 3pt and remote hydraulics not to work. By dead heading the remote hydraulics by pulling the remote hydraulic lever with nothing attached to the remotes is sometimes enough of a shock to the hydraulic system to free the stuck priority valve in the MCV.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
