Re: Farmall F-12 carb problems
Posted by FarmallCT on May 15, 2014 at 17:34:58 from (24.191.226.58):
In Reply to: Re: Farmall F-12 carb problems posted by John M on May 15, 2014 at 17:29:14:
Okay, then it may have been just the needle valve but I know it did keep locking when I put the carb back together. I tried squeezing the clamp that the pin goes through but it still moves. Would a small spring work to keep it from locking? I think it also may be the gas went bad. I put some of the gas from the fuel tank in the carb and it wouldn't start until I put in fresh gas. Is there any way to clean the tank and seal it without spending lots on the expensive name brand sealers? Thanks for all the help.
