Re: Farmall 140 Transmission NEED HELP
Posted by mkirsch on May 16, 2014 at 05:28:07 from (65.199.189.6):
In Reply to: Farmall 140 Transmission NEED HELP posted by RTR on May 15, 2014 at 13:43:07:
Ok, when you take the shifter off this time, make note of which forks are in which positions.
Do the forks slide smoothly, or pop from position to position? Smooth is bad. Means the detent balls have fallen out. Transmission has to come apart.
If the forks pop from position to position, then you're not getting the ball on the end of the shift lever aligned with the slot in the shift forks.
This post was edited by mkirsch at 05:28:31 05/16/14.
