Re: B275D sediment bowl leaking
Posted by michael soldan on May 16, 2014 at 13:23:06 from (24.235.39.66):
In Reply to: B275D sediment bowl leaking posted by Vito on May 16, 2014 at 11:19:37:
On my B250 I had a similar problem,a new gasket didn't seem to solve the leak,I don't know if the gaskets are thinner or what,but I made a gasket out of corkboard,that was considerably thicker than the rubber/neoprene one and the leaking stopped. I had to retighten as the gasket took the shape of the bowl up against it..no problems since
