Re: 400 belt pulley shaft seal
Posted by truckerlary on May 16, 2014 at 18:52:59 from (207.141.127.201):
In Reply to: 400 belt pulley shaft seal posted by Fudd on May 16, 2014 at 16:07:49:
Taking the bolts out of the flange will let the shaft come out but if I remember right the the long center bolts that hold the housing down have to be pulled up out of the way as they catch on the bevel gear. Someone correct me if I'm wrong.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
