No doubt the base is warped giving you the problem. A good thick cork gasket, softened up good in very hot water,(I used to use the steam cleaner on cork gaskets to get their attention) would be your best bet. I always softened the cork valve cover gaskets etc also on a lot of machines. It was pretty common for a valve cover to be warped out of shape and a nice soft gasket was what was needed instead of a lot of gasket cement. The gaskets increased in size also, so you had to kind of push them in place under the cover as you started to tighten cover down but they really seal good then.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
