I recommend the international 125B with a 4 in 1 bucket. It is a turbocharged Deutz diesel, wet steering clutch design that is practically indestuctible and you can steer it with two fingers. They have self leveling buckets, and nitrogen accumulators in the hydraulics to absorb the shock when the bucket drops instead of your back. Biggest maintenance is the track frame, idlers, sprocket and chain. Normal use area. If they are ok, you will love it. The 100B is mechaically about the same but no turbo.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
