Re: If You Were Going To Buy a Crawler
Posted by Jim Becker on May 17, 2014 at 07:01:15 from (173.71.58.166):
In Reply to: If You Were Going To Buy a Crawler posted by PRTZMAN55 on May 16, 2014 at 12:29:07:
There are plusses and minuses to the Cletrac steering system. Yes, trying to turn when you are at the limit on pulling can be a problem, and they do like to wander when you are going straight ahead. On the other hand, the steering doesn't start working backwards when you are going down a hill. With clutch steering, if the engine is holding back and you pull the left steering lever, the clutch disengages and that track speeds up until you pull hard enough to apply the brake. Then the unintended right turn starts to become a left turn. This is a valid consideration if you are working steep grades.
By the way, the Cletrac differential does not have bevel cut spider gears. The only bevel gears are the ring and pinion.
