Re: At my wits end with needle valves
Posted by Roger in Iowa on May 17, 2014 at 15:24:33 from (166.181.82.179):
In Reply to: At my wits end with needle valves posted by Mr. Farmall A on May 17, 2014 at 15:15:33:
Can you shut off the fuel each time you are going to park it for awhile and let the tractor run until the carburetor is empty? Then the needle valve will not be in the sticking position....
Don't forget to turn off the ignition after it stops!
