Re: Lift All Belly Pump Works Intermittently
Posted by Janicholson on May 17, 2014 at 16:29:01 from (74.60.94.18):
In Reply to: Lift All Belly Pump Works Intermittently posted by Jason G Fabian on May 17, 2014 at 15:04:59:
Put the pressure gauge in the front left elbow with a T so it can operate and read pressure.
There could be a hose with a collapsed internal flap that acts like a check valve.
The lever could be loose where it pivots at the pump.
If none of those help. you might need to remove it and look at the internal linkage. Jim
