Re: Lift All Belly Pump Works Intermittently
Posted by rankrank1 on May 17, 2014 at 18:59:38 from (166.137.101.157):
In Reply to: Lift All Belly Pump Works Intermittently posted by Jason G Fabian on May 17, 2014 at 15:04:59:
Can not really help you on the troubleshooting, but since you say hydraulics work intermittently: I am hoping you do realize that belly pump hydraulics only work when the clutch is released (you can be in neutral or moving in any gear).
In other words, Belly pump hydraulics do NOT work when the clutch is pushed in.
