Re: went look at farmall h
Posted by clint s on May 17, 2014 at 20:36:32 from (67.242.45.169):
In Reply to: went look at farmall h posted by Nate V. IA on May 17, 2014 at 20:30:04:
I would have put it in 5th pulled the plugs and just try to rock it. If the fan moves it is probably good. Like Nate said If it was hydro locked or the sleeves full of rust, bent/broken rods, crank and stuff. You can also break a ring on an engine that might have been able to be saved.
