if this is a good running tractor with constant good oil pressure,
I'd just leave it be. Breaking or stripping a worn rod cap bolt to just change those clips will ruin your day.
With that said, when I buy a tractor, especially a Farmall where it is so easy.....and I have the oil pan off for cleanup....
dunno..can't resist I guess.
At a minimum, I'll put new rod bearings in (same size that are in there) Then plane the oil pump cover plate, and put a new gasket in it.
Peace of mind for under a hundred bucks.
(And every time, I didn't...I regretted it later)
old parts get labeled and saved. Got an engine right now that is not worth a single dime. But with my old 'not too bad' bearings and engine parts collection, it's going together with all used parts. Correct...no, will it run and be useable..yes
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
