With that added symptom, I am going to suggest that a needle valve makes little difference in surging. What will make a difference is mixture. Richer at higher load will cure that. IIRC that carb does not have an adjustable screw for power richness. A higher float level (1/16") or a larger jet size are in the right direction. Don't ream out your main jet, purchase a new one and experiment on the old with number drills only very small steps at a time. Tiny increments adjust flow big steps dump gas into the system. Jim
Today's Featured Article - Preventing Tractor Theft - by Staff. The discussion started with the following message: I have a JD A without key start or any locking device. Is there a best way to secure it so the chances of it being stolen are reduced? Following are some of the answers that were received: Take the rotor out of the distributor and hide after each use. The would-be thieves at least couldn't just get on and drive away.
... [Read Article]
Latest Ad:
[More Ads]
