Re: Carter UT/ Farmall 200 no start stall
Posted by clint s on May 18, 2014 at 06:15:37 from (67.242.45.169):
In Reply to: Carter UT/ Farmall 200 no start stall posted by gene bender on May 18, 2014 at 03:04:50:
Well Gene yesterday after reading a few of your posts I took a piece of welding wire are really ran it through all holes good. That's when it started to run after cleaning the points and it seems to be starting well now. I will disc the garden this week and see. It seems to run better now and will idle on the lowest notch of the throttle smoother.
