Re: Farmall Cub pto pulley
Posted by Dan Robertson on May 18, 2014 at 18:11:52 from (98.223.249.230):
In Reply to: Farmall Cub pto pulley posted by RockyMO on May 18, 2014 at 17:45:56:
third party image
I just went out and measured the pto pulley on my cub which has a woods 42c mower. It measures 7 3/4" outside dia. It runs the mower fine. About 8" is as big as will fit if your tractor has the rear lift arm in place. This is a non-fast hitch tractor. Fast hitch requires a whole bunch of different items to accommodate the mower. The cub 22 sickle mowers used a 4" and later a 4 1/2" dia. pulley.
Dan Robertson
