Re: stuck starter
Posted by gene bender on May 19, 2014 at 00:01:31 from (67.55.226.121):
In Reply to: stuck starter posted by Dave Innerebner on May 18, 2014 at 20:01:17:
I would pull the starter out and clean the drive with wd-40 check the ring gear on the engine when its out looking for bad teeth.
