Yes, you can still clean it, but do NOT use a tooth brush or anything else like that. Just spray it liberally with carb cleaner and either blow it dry with compressed air or just lay it on a clean shop towel and let it dry.
Might also want to make sure you don't still have some old, varnished up gasoline in the tank, and make sure the gasoline you add to the tank is also clean and fresh.
I've been using the ethanol blended gasoline ever since it was introduced in the late '70s, early '80s, and I use it in everything I own. Ethanol is the best thing that ever happened for these old tractors. If it caused problems, I would not use it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
