Re: MD headgasket oil leak
Posted by Mine leaked there as well on May 19, 2014 at 07:54:04 from (199.17.6.22):
In Reply to: MD headgasket oil leak posted by DanMD on May 19, 2014 at 02:48:08:
Look at the second page back MD spun Rod bearing Bruce S. The Post with Update is some of the answer, the post farther down is more.
Mine leaked and I cleaned it with laquer thinner and sealed it with a coating of urethane door and window sealer. I let it cure for 2 days and it stopped leaking (at least on the outside). As long as the head is getting lube, it will be fine. Jim
