Posted by Charlieu on May 19, 2014 at 11:03:19 from (209.131.225.156):
In Reply to: U-6 starter posted by TractormanNC on May 17, 2014 at 12:55:31:
I did not get to my shop untill this morning and here are a couple pictures of the starter that I have The Delco part# is 1107768. It's a 12 v, CW, 10 tooth Bendix drive, with Magnetic switch, 3 bolt mount. The bolt pattern is the same as a 560. I have a 560 with the starter removed, so I tried the starter and the bolts fits. My e-mail is open.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
