Re: stuck starter
Posted by rustyfarmall on May 19, 2014 at 11:07:52 from (208.126.186.41):
In Reply to: stuck starter posted by mkirsch on May 19, 2014 at 07:01:39:
No, if the starter drive is stuck in the teeth of the flywheel, it will not make even one click. I've been there.
