top link holes
Posted by BigTone on May 19, 2014 at 14:35:01 from (70.209.137.161):
I have 3 holes on my back blade for the top link, same as on the 3 point hitch. When I hook up the blade do I need to match the holes on both the implement and hitch with the top link? For instance, for max lift height I know use the 3rd hole, should the top link be in the 3rd hole on the implement as well or is there an advantage to hooking it to one of the other holes? thanks, Anthony
