Posted by Bob on May 19, 2014 at 19:23:51 from (75.238.189.14):
In Reply to: farmall 560 regulator posted by farmall560guy on May 19, 2014 at 18:55:42:
Is the charging system working?
The reason I ask is that there is typically a flexible, braided copper wire that jumpers from the regulator frame to the tractor chassis mounting area where the rubber mounts attach, and once this breaks the charging system no longer charges.
I suppose, if you are mechanically adept, you cold bolt some new strips of rubber belting in place of the (rotten) factory stuff and save the cost of a regulator.
Otherwise, you are stuck for a new one.
Regulators do NOT need to be polarized. EVER. Under certain circumstances, generators DO. (If they've been dis-assembled or sat unused for YEARS.)
Often, this is done at the voltage regulator, for easy access to the necessary terminals/voltage.
Since this is a Delco "A" circuit system, momentarily jumping "BATT" and ARM (or"GEN) at the voltage regulator will polarize the GENERATOR.
Which you should NOT need to do, if simply replacing the VR.
But, if done as directed, it won't HURT anything IF you polarize the genny.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
