Posted by 806jr on May 20, 2014 at 01:34:50 from (199.223.221.145):
In Reply to: 806 pto issue posted by Cornbower on May 19, 2014 at 22:09:16:
Check your splines on the IPTO shaft, this is the hollow shaft that has the smaller shaft sticking out of it, the splines will wear thin and then will start to bend over. Also check the splines inside clutch pressure plate that the IPTO shaft slides into, they might be worn down to. It could be something inside the pto also, sounds can travel to different areas threw the shaft that runs the pto.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
