Re: 240 Engine swap
Posted by mkirsch on May 20, 2014 at 12:51:23 from (65.199.189.6):
In Reply to: 240 Engine swap posted by Mo in NE Tx on May 18, 2014 at 15:51:18:
My guess is he's makin' a puller out of it.
All you really need is the governor off a 240 to get the RPMs. The main difference internally in the engine is a slightly smaller combustion chamber in the head on the 240.
If your Super C engine is strong with good compression, and you're really only after the power for pulling, go for the governor.
