Posted by wfd2 on May 21, 2014 at 19:01:40 from (72.104.71.144):
Four years later I'm having the same problem with my '47 H. Sure enough the battery cable stud was the culprit. But, in my case, it was shorting to ground.
Check to see if you have continuity between the battery cable stud and the case. If you do, the stud is cracked and shorted to ground inside the starter.
I took mine apart, straightened out the lug and soldered the connection. Starter works like a charm.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
