Re: 340 pump hyd keeps pushing seal out HELP PLEASE
Posted by pete 23 on May 21, 2014 at 19:23:22 from (74.33.76.120):
In Reply to: 340 pump hyd keeps pushing seal out HELP PLEASE posted by john banet iii on May 21, 2014 at 15:38:13:
Most original pumps were staked around the seal. Not with a center punch but rather with a flat tool. If you did not remove those slight indentations when installing new seal it deformed the new seal. I have used Loctite and also staked them. If the bushing is worn it will probably move the seal anyway or at least leak. Have seen many many seals pushed out when pumps were worn out although you do get lucky now and then.
