Re: Stper A Engine Speed
Posted by JRSutton on May 22, 2014 at 04:02:30 from (71.174.108.245):
In Reply to: Re: Stper A Engine Speed posted by mkirsch on May 21, 2014 at 13:41:38:
Exactly
But it does also kind of depends on what gear you typically mow in.
If you mow in 3rd, at 5mph - bump it to 1800rpm and you'd be going 6mph.
But if you shift down to 2nd, at 1800 you'd be going between 4 and 4.5 mph.
That's slower than normal in 3rd. But might not be horrible. That's a personal decision.
If you can live with that decrease in speed, that'd probably give you what you're looking for in better mower performance.
It'd be spinning 20% faster, and the travel rate would be decreased, lessening the load on it.
Just remember to throttle down in reverse!
