Posted by SW EM on May 22, 2014 at 07:04:11 from (67.55.191.201):
I have my TA disassembled right know and am deciding what to replace. I know I need new rollers, pins, springs, and plugs. But do I need to replace the "Ramp" that all these parts are in. There was quite a bit of flat-spotting on the rollers and there was pieces of metal around them (Probably due to the flat-spotting). If I do replace the parts mentioned above, including the ramp, is it ok to buy .010" over-sized rollers. This website has exactly what I need but the rollers are over sized.
The reason I"m rebuilding this TA is because the tractor would stop and whine when the TA was engaged. So I was told to check out the ramp and rollers. Everything else looks good. So is it safe to assume that the TA will work when I replace the ramp and rollers?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
