Re: 986 hydraulic problems
Posted by pete 23 on May 22, 2014 at 10:05:08 from (74.33.76.120):
In Reply to: 986 hydraulic problems posted by D Sellers on May 22, 2014 at 08:20:02:
Sounds like failure of bearing in transmission or final drive. I drain each plug separate to see which compartment has the bulk of the filings. Any time you get metal on the screen that tells you the filter is plugged and oil is going through the bypass screen valve. There are four different plugs to drain. Pump won't put enough crap in filter to plug it as it will quit pumping altogether before that.
